Problem with scanning
Hello!
Since some days ago i have a problem with DTO and my Canoscan LIDE (25 & 35) on my MacBook with Lion.
I have used the Beta scanner-plugin and adjusted a rotation of a scan. Since then i get a this message every time i use the scanning-plugin (not the beta) on both scanners
“Sie haben eine benutzerdefinierte Drehung eingestellt. Wollen Sie diese behalten oder Rückgängig machen?” (“They have set a custom rotation. Do you want to keep it or undo?”)
I would like to get rid of this message and it´s effect: if i use “keep” all scans are rotated be 90°, if i rotate them with the software i get the scan rotated by 90° but the orientation keeps landscape. This means the image is compressed on the height of the landscape canvas.
All rotations in both beta and original plugin are set to 0°.
Any help would be appreciated.
Regards,
A. Wolff
