Using the script: Export/listing, I have started getting the following message.
sh: -c: line 1: unexpected EOF while looking for matching `"
sh: -c: line 2: syntax error: unexpected end of file
Can someone explain the problem?
Many thanks.
Many thanks.
SM,
which filename and which destination folder did you use? Because I couldn’t reproduce this issue over here.
My database is called Research, so the script suggests Research.txt and I’m saving to the desktop.
It has been working fine, but problems started occurring recently. The script will progress satisfactorily and then hang, producing the error message above.
Thanks
Did you change anything recently, e.g. use a different username or account?
No - it’s a longstanding d’base.
The only thing, that may or may not be significant, is that I did a lot of tidying up, mainly renaming items to more sensible titles, and I often used the contextual menu ‘set title as’ after selecting text.
However, the script seems to run fine through most folders, getting stuck eventually with its error message. At the moment it’s sticking over a folder with email messages transferred from’mail’ - but these are plain text and have not been retitled.
Thanks for help.
How many contents/groups (see File > Database Properties…) does the database contain? Maybe it’s just too much data for this simple script.
It’s indeed an overflow, here’s a revised and more stable version of the script (please note that the script is now using UTF-16 instead of UTF-8 encoding)
-- Create Listing.
-- Created by Christian Grunenberg on Sun Jul 24 2005.
-- Copyright (c) 2005-2006. All rights reserved.
using terms from application "DEVONthink Pro"
activate
if not (exists current database) then error "No database is open."
set theDatabase to the current database
set theFile to choose file name default name ((name of theDatabase) as string) & ".txt"
show progress indicator "Creating Listing..."
set theListing to my createListing(children of root of theDatabase, "")
set thePath to POSIX path of theFile
if thePath does not end with ".txt" then set thePath to thePath & ".txt"
set sysInfo to system info
set writeFile to open for access file ((thePath as POSIX file) as string) with write permission
set eof writeFile to 0
if ((CPU type of sysInfo) as string) contains "PowerPC" then
write (ASCII character 254) to writeFile
write (ASCII character 255) to writeFile
else
write (theListing as Unicode text) to writeFile
close access writeFile
-- do shell script "echo " & quoted form of theListing & ">" & quoted form of thePath
hide progress indicator
display alert "DEVONthink Pro" message error_message as warning
on error number error_number
if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
on createListing(theseRecords, theTabs)
local this_record, this_type, this_listing, this_name
set this_listing to ""
repeat with this_record in theseRecords
set this_name to (name of this_record as string)
set this_listing to this_listing & theTabs & this_name & return
set this_type to type of this_record
if this_type is group or this_type is sheet then
step progress indicator this_name
set this_listing to this_listing & my createListing(children of this_record, theTabs & tab)
return this_listing
end createListing
end using terms from
Thank you - that works a treat.
For anyone who is interested, the listing will open in Omnioutliner, and can also be sent to Tinderbox, if you want to make a visual map of a database.
SM
It’s also possible to export the structure of a database as an OmniOutliner file (see File > Export > as OmniOutliner document…) which can be imported by OmniGraffle to create a visual map.
An export to OO includes all the text in folders and items. Export listing via the script assembles the file names only within their folder structure. Very elegant - useful sometimes for reorganising a big database.
