using terms from application "DEVONthink Pro"
activate
repeat with this_record in this_selection
if (plain text of this_record is "") and (type of this_record is not group) then
set old_date to modification date of this_record
display dialog ("going to convert image")
set converted_record to convert image record this_record
display dialog ("setting date...")
set the modification date of converted_record to old_date
display dialog (modification date of converted_record as string)
display(error_message)
end using terms from
Could someone explain why when this script is run from Script menu it does not set modification time, but when run from edit editor it sets the modification time just fine? It is driving me crazy? I’ve made sure it is saved, saved to a new file name, updated the script menu items, restarted the application… It’s very strange!!
The display dialog “setting date” is actually never shown when run from within application. It’s almost like the script dies after doing the image convert and adding that record to database.
No, that didn’t help. I even tried moving the timeout around the entire thing. It is almost like IRIS is timing out coming up… because now I am not even seeing the IRIS dialog pop up.
But again, running this from script editor works 100% fine…
This is the script I use in the Convert\ Selection\ using\ OCR.workflow example:
on run {input, parameters}
local output, aRecord
set output to {}
repeat with aRecord in input
with timeout of 3600 seconds
-- New record is created in same group as aRecord by default
set newRecord to convert image record aRecord
set output to output & {aRecord}
on error errMsg number 9104
-- Possible errors that are returned (numbers subject to change):
-- kIRISProcessingError = 1003
-- kIRISMaxOCRPageExceededError = 9100
-- kIRISNoOrEmptyFileError = 9101
-- kNoImageRecordError = 9102
-- kExportImageRecordError = 9103
-- kPDFImportFailedError = 9104
-- kUnknownExceptionError = 9105
log message errMsg info (name of aRecord) & ": Check “~/Library/Caches/DEVONthink Pro/OCR” for files that weren't imported"
end timeout
-- Returns successfully converted records (to be moved aside)
return output
end run
Thanks, but that doesn’t help as the problem only occurs when running the script from within DT.
Here is the simplest script I could come up with which replicates the problem on multiple machines. Can someone else please confirm whether or not it is reproducible in their environment?
activate
set the_selection to selection
set this_record to item 1 of the_selection
end timeout
display dialog (error_message)
Your script works fine over here. Try to clean your LaunchServices database and check if it works better afterwards. I’ve had strange AppleScript problems before that got fixed by this simple action. Any cache cleaning tool will do the job.
I’ve used maintenance to do as you suggest and clear the launchservices database and still get the same result. What should I do at this point?
It does the same thing for me on two different machines.
What else can I try?
I really need to get this resolved as I have a bunch of PDFs I need OCRd and I want to do it via a script to keep modification time in tact. It seems anything which executes the convert to image command in the script isn’t going to work.
Christian, the actual document being OCR’d doesn’t matter. It occurs on each document. I’ve tried it on .JPG documents, or PDFs without text… It occurs with a blank database or my database with 1.5G worth of documents. It occurs on a new user profile, or my existing user profile. The script I used is the one posted in this thread. Nothing more then OCR’ing the selected document. Very simple stuff.
The funny thing is that script works perfect when running from script editor.
Would be happy to provide access to my machine to show you examples of what is happening so that we can get this resolved.
You are correct, if you execute this script inside DT it fails. And I have no idea why. While we’re investigating, there is a workaround (as usual). You can put this script inside an Automator workflow and put that workflow in the Script menu by replacing it with your current script. Since Automator runs in a separate process, it won’t trigger the problem.
Can you try this again with 2.0pb3? I just looked at it and it seems to work now (admittedly with the upcoming version of the OCR plugin but nothing changed in the run model). If not, then try with 2.0pb4 when it comes out.
