I have two problems when scanning and importing documents with Import -> From Scanner - With Capture
1 - sometimes, the first page looks fine at the preview and immediately after scanning, but then after OCR is performed, the page looks like it has been stretched enormously vertically. The text is unreadable, looks like barcodes. I usually just hit Add Page and it scans the page again, and this time its OK. Then I delete the first. It only happens to the first page, all successive pages are fine.
2 - after I have added the scanned document to the database (final step), I always get a log window up with a “Failed” message. but everything looks fine, the document is scanned OK, and it is available in the database. what is the error message trying to tell me? here is an example, I saved the log file, here is the contents from the last scan:
10:47:44: /var/tmp/folders.501/TemporaryItems/Playfilms Avtale.pdf Failed
Please note; problem 1 and 2 are independent from each other (2 can happen if 1 does not)
I am using Devonthink Pro office 1.3.1, OSX 10.4.9 and a Canon MP 600
