Problems importing Excel into a sheet
I’m trying to import an Excel sheet as a sheet. Oddly, it insists on naming the individual records according to the FOURTH column in the sheet, rather than the first, which is what I want.
I’ve saved the Excel sheet as a CSV file.
FIRST ROW
Last Name,First Name,Department,Title,Primary Office,PO Box No,Phone,Secondary Office,Secondary Phone,Email Address
SAMPLE DATA ROW
Abdel-khalik,A. Rashad,ACCY,“Professor & Director, CIERA”,320C WH,84 WH,5-0539,rashad@uiuc.edu
I’d prefer that the sheet be called “Abdel-khalik”, my colleagues last name. But, it is being called “Professor & Director, CIERA”. Tried all sorts of things and can’t get it to change.
Any hints.
Thanks!
That sounds odd indeed. As a temporary workaround: What happens if you insert three empty columns before the first?
This would merely be a workaround, but maybe it helps bridge the time until someone comes up with a real solution.
Prion
You can change the name of a sheet in the Info pane.
And you can edit the names of each column header to whatever you wish.
Select Data > Sheets > Edit Columns.
Actually it should work that way - could you send me a small sample file? Thank you!
EDIT: Found the problem - DEVONthink is trying to be too intelligent and using the “Title” column to name the records.
That was exactly the problem. When I changed “Title” to “Position” it worked perfectly. Thanks!
