Problems/questions re "take note"
I see two ways to take a note, neither of which seems to perform in the way one would expect:
  1. In the Data menu, the “New from Template” drop-down menu includes “Note.” This function – incorporating highlighted material or screenshots automatically – is terrific…just what I need. But is there any shortcut by which I can open it in one step? I’d rather not have to go through the three steps of DATA>NEW FROM TEMPLATE>NOTE every time I need to use the function.
  2. From the toolbar, clicking on “Take note” opens a separate “Take Note” box - different from the new note opened by the process described above. When I enter a title, then enter some content, then press “save,” I get a notification that says: “Couldn’t save your note in the database; It has been saved on your Desktop as ‘Unsaved note.txt’.” Am I doing something wrong?
Thanks,
Jim Tobin
You can assign a shortcut via System Preferences > Keyboard & Mouse. Or simply by renaming the template, e.g. to Note___Cmd-Ctrl-Alt-N.templatescriptd (DEVONthink Pro) or Note___Cmd-Ctrl-Alt-N.dtTemplate (DEVONthink Personal).
Which edition of DEVONthink do you use?
Thanks very much – already helpful – I use DT Pro Office.
jt
Are you able to reproduce the problem? And have been any databases (including the global inbox) opened?
Yes, the same problem recurs. The Global Inbox does not open.
I’ll ask a modified question, based on some more fiddling around that I’ve just done. What I’d like to do is this:
  • Let’s say I’m looking at a PDF file that resides in Group A in DT Office Pro.
  • I annotate the PDF. Now I want to create an annotation of the type that I would get if I selected DATA>CHOOSE FROM TEMPLATE>Annotation. The annotation will appear as a new document in that same Group A.
How should I create a keyboard shortcut that will carry out that sequence of selecting DATA>CHOOSE FROM TEMPLATE>Annotation?
It should be automatically opened. Any alerts on startup?
The default shortcut is Cmd-Shift-Alt-A.
No alerts appear at startup
[/quote]
And is there a default shortcut for the same operation, this time opening a new “note” instead of an annotation?
Do you use a demo without any trial time left?
There’s no default shortcut in this case, you have to define your own one (see above).
About the version I use – No, it’s not a demo – at least, I don’t THINK it is. It’s DT Pro Office 2.0.2.
About the short cut – I see now. Thanks very much.
