Has somebody this setup running successfully?
I got the latest drivers and updates installed but I can’t get a preview when I scan with DT. Both Canon’s Navigator and Apples Digital Pictures show a preview where I can adjust the area I actual want to scan so it shouldn’t be a general problem of the scanner driver. When I ignore the missing preview DTO scans the hole scanning area so every little reciepe produces an impressive oversized pdf. Beside that I there are stability issues while saving the scanned and ocr’ed document. DTO freezes and needs a forced quit.
The preview used to work under OS 10.6, problems startet with 10.7 both with DTO 2.2 and 2.3. (I know: never touch a running… )
Is there some trick or do I have to go back to OS 10.6 again?
Thanks a lot!
