It is not really important. About once a day it happens that protecting a document with a click here does not work (DT3)
A click here always works.
Or restarting DT.
I don’t know if this is also the case with DT4. I just wanted to mention it.
Or restarting DT.
Most of my documents are RTF. But I think it also affects others.
What OS?
Ventura.
I have just one.
No.
Let us know if you see any consistency in the behavior. Yours is the only report I’ve seen.
Which view do you use for the item list? In the end both toolbar items, the menu item and the shortcut all trigger the same code, therefore they should always work the same.
Please choose Help > Report Bug while pressing the Alt modifier key and send the result to cgrunenberg - at - devon-technologies.com - thanks! Maybe there’s a hint in the logs.
