I know how to password protect a database but would like to be able to protect a Group rather than the whole database—is this possible? The documents I have inside this particular Group are mildly sensitive so I think password protection would be sufficient although I would consider encryption of individual documents if that s also possible.
Not possible with a group. However with Acrobat or various archive utilities you could create a password-protected PDF or archive, respectively. These can be stored in DEVONthink but Search, Classify, etc., will not be able to do much since the content will be hidden.
Thanks Korm, that is helpful advice.
