I can not get this query to work: " “~term1 term2” " (only the inner quotes are query-relevant)
I got no results. What do I do wrong?
Best and thanks for helping me, Matze
EDIT: maybe it has got to do with the tilde?
Manuals advice “~term1: Contains all words that begin or end with term1 (words containing term1 as a part of the word; depends on the queried search engine)” doesn’t work at all. I copied the ~ from the manual.
Thank you Matthias, but this one ~“ige wörter” (to find lists of “lustige, eigenartige, eklige, merkwürdige wörter”) finds two pages. One with “Häufige Wörter” one with “unanständ’ige Wörter”
When I search for “merkwürdige wörter” I get 112 pages!
The ~ operator is an add-on of DEVONagent and not supported by any major search engine. Therefore it’s basically intended for search sets querying sites on their own and not using search engines.
