Morning.
I want to find in a smart folder all items which (a) contain a specific word and (b) not reside in a specific group. Because I want to move these scattered items into this specific group.
How can I achieve it?
Thanks in advance for your support!
Kind regards, Friedrich
You can’t have multiple locations for where to search in a smart group, but you could search for your specific word, add the Location column to your search results, and then sort the smart group results on Location.
If groups are not excluded from tagging (see File > Database Properties), then a smart group like this should work:
Kind is Any Document
Tag is not
