I recently purchased Devonthink and I subscribe to a historical newspaper service that allows me to download copies of each page of a newspaper. I would like to download a copy of each issue of my town’s local newspaper from the 1880’s to about 1980. I have several questions and would appreciate your advice:
As I download the .jpg images I assign a name to each corresponding newspaper page in this format: Newspapername_YYYY_MM_DD_pg1. Then I add the pages to a file folder named NewspaperName_YYYY_MM_DD. Is there a drawback as far as Devonthink is concerned to this method? Would it be better to add the pages to a .pdf document named Newspapername_YYYY_MM_DD without bothering to name each individual .jpg page?
The downloaded .jpg of each page is enormous at 4819 x 7549 6.6MB 72 pixels per inch. Can you give any guidance as to far I can reduce the image size?
Currently my Devonthink OCR doesn’t recognize the newspaper columns, instead it reads left to right across all columns. Is there a setting to force Devonthink OCR to recognize that this document is a newspaper and it should recognize the columns?
Do you have any other tips for using Devonthink with backissues of a newspaper?
