If someone uses BetterTouchTool in addition to Keyboard Maestro, here’s a tip on how you can set tags very quickly and effectively.
By holding down the Shift key I make a mouse tab on the left and get my desired tag inserted.
Here is an example:
Here is the Keyboard Maestro macro for it:
Here is the script from the macro:
-- Append selected tags
set thisSelection to the selection
set allTags to selected text of think window 1
if allTags is not "" then
set {od, AppleScript's text item delimiters} to {AppleScript's text item delimiters, ","}
set theTags to text items of allTags
repeat with theRecord in thisSelection
set tags of theRecord to (parents of theRecord) & theTags
