Hey, I am kind of new to Scripting and was wondering if anyone could tell me whether the following is possible or not and to guide me on how to do it:
I want to create a script that opens a random file (usually a personal note, plain or rich text) from a certain Database or Group. I guess the random part is where I am lost in trying to write the script.
set theContents to (contents of current database)
set theContent to some item of theContents
open window for record theContent
Took me a while to figure out how the “contents” of a group were called, but for those who like me struggle with Script, this one will pick a random note from the currently selected group:
set theContents to (children of current group)
Bluefrog — The script is written to pull a note randomly from a certain group. How would you set it to first select a random group … and then pull a random note from that randomly selected group?
property ignoredGroups : {"Tags", "Inbox", "Trash"}
set theDatabase to current database
set groupList to (parents of theDatabase whose (location does not contain "/Tags")) -- Filtering out the Tags groups as they are parents as well.
set randomItem to some item of groupList -- This is asking for a random item in the list
if (name of randomItem) is not in ignoredGroups then -- Ignoring anything specified above
set fileList to (children of randomItem whose (type is not group) or (type is not smart group))
-- Groups and smart groups can be children so filter them out
if (count fileList) > 0 then -- If there's more than one file in the random group
set randomFile to some item of fileList -- Grab a random file
open window for record randomFile -- Open it in a document window
else -- Otherwise alert the user a random empty group has been chosen
display alert "No files in: " & (name of randomItem)
This is nearly exactly what I need. However, whenever I run the script, “randomItem” is always a randomly selected Group but not a randomly selected note from within that randomly selected group. Since receiving your tip I’ve been trying to tweak it to exclude Groups from the selection process so that it only grabs a document or file (like you did with Trash and Inbox), but with no luck. Thoughts?
But the general idea is if you have something like an external brain, similar to maybe a personal wiki, and in my case called a Zettelkasten (translated from German as note box or box of notes), you sometimes save information that you either forget or that isn’t really ready to write down etc.
Usually all info in my Zettelkasten is linked to other info bits. But sometimes, when I’m writing down info that doesn’t relate to all existing info, a note goes unlinked to other notes. Unlinked notes can be forgotten and never be used again (which either means you never needed that knowledge again or you have it twice in your system and the links go to the twin).
Also, I never copy much text from what I read but formulate my insights in a new way, only seldomly using direct quotations. So improving my own writing is always in demand.
And thirdly, this is about serendipity. I collect notes whenever I read and so far my Zettelkasten consists of about 200 notes with summarisations of books or articles and about 500 notes of personally formulated insights from all my work. Of course I cannot remember them all. Random looks at some of them might trigger a new idea for a current project etc?
So these are the three reasons for a daily random note reading: checking the linking, optimizing my writing and invoking serendipity!
I have two groups with Zettels in them (for the time being), one for source notes and the other for my idea/thinking notes. So my script looks like this:
set theGroupZ to (get record with uuid "put id here")
set theGroupQ to (get record with uuid "put id here")
set theContentq to (children of theGroupQ)
set theContentz to (children of theGroupZ)
set zufall to (random number from 0 to 1)
if zufall > 0 then
set theContent to some item of theContentz
else
set theContent to some item of theContentq
