hi, seems to be a little bug with new release.
if i click on tag filter, the focus move to main view top tag filter field, but tags cloud is not shown, i need to activate locations pane and after return to tags to fix it.
this is happened many times last days
I’m not seeing an issue here.
A screencast or screen captures would be helpful.
the first time is happened right after updated to 3.5.1
now i willl try to replicate it
Which version of macOS do you use?
10.14.6
is happened again this morning, not a big problem, tags pane does not open until you go on location, this fix it.
Screenshots before/after opening the filter would be useful, thanks.
What’s the difference of the used workspace?
when i switch to a workspace with 4 windows opened on different smartgroups, without sidebar,then i switch again to original workspace, the tag pane is freezed.
Weird. So far I couldn’t reproduce this. Maybe screenshots of the full window before/after restoring the workspace and after opening the Tags filter will help. Thanks in advance!
i’ve narrowed the use case: this happens when one of the windows in the second workspace has tag filter pane selected (with sidebar closed i wasn’t aware) switching back to first one tags pane freeze.
I can’t reproduce this here either.
However, I saw this artifact…
- Open a single main window.
- Show the Tags filter pane.
- Hide the Navigate sidebar.
- Add as a new workspace.
- Open another window.
- Load the workspace.
- Show the Navigate sidebar.
Hiding and showing the Tags filter fixes this until the workspace is used again.
- Add as a new workspace “two”
- Load workspace “one”
- Load workspace “two”
- Tags freeze
Okay. Yes, I can confirm that here.
