Question: I created a reminder for a Smart Group which causes the same reminder to appear for all smart group in the given database (instead only for the given smart group).
This seems like a bug to me. Or is it a feature?
Are you sure that only the desired smart group and not multiple ones were selected? At least that’s the only way I can reproduce it.
Only the desired smart group was selected.
In the sidebar or in the main view?
OKOK. You got me. I was in the sidebar. Switching to main view did the trick. Thanks.
Maybe this is worth investigating either…
Just tried it but this works fine here. A screenshot showing the sidebar & the main view while adding the reminder would be great!
Does this help?
1.pdf (701.8 KB)
Is this a global smart group in the Smart Groups section of the sidebar or a local smart group inside a database?
It’s a local one in a database.
Just created a new database, selected one of the default smart groups in the sidebar, added a reminder via the inspector but only the selected smart group got the reminder as expected. Are you able to reproduce the issue?
Same here: It works with a new database. Strange…
