It’s been a while since i’ve needed to login here. I’m not sure whats happening but the rename script in DT3 has stopped working. I’ve tried single files and multiple. I’m not sure where to begin to try and reclaim this quite important functionality for me. Happy to give details or be steered in the right direction.
Glen, Frankly I know nothing about the Rename Script as I don’t use it or something like it, but to get some help here, best if you describe the symptoms of the problem, what you are trying to do, and perhaps also give a listing of the actual script you are using. Without it’s difficult for anyone to help in any effective way.
Hi there,
Not sure what you mean but I just tried again and just wrote 'example in the dialogue box. Thanks for getting back to me…Still keeping fingers crossed.
Good point Chrillek,
Well the last time I used scripts heavily was around a year ago (and on a different computer) I remember installing extra renaming scripts before that had more functionality. The default one in DT3 works differently and I didn’t immediately understand how to use it…Till I asked here
