Replicants and Duplicates work not across databases. - I guess that’s by design?
At the same time it looks to me like a missing feature…
AFAIK, duplicates do work across databases (because they are copies, initially), and replicants don’t. The latter is probably a technical limitation of the concept.
@chrillek is correct. It’s down to your “design” of databases. Don’t get them so segregated that the inability to use the powerful replicate feature gets in the way. I do a lot of replication in my main database “Interesting Stuff” as it helps with research later (which is the point of all this DEVONthink activity for me.
I wasn’t clear in my initial post: I meant replicant and duplicate detection. I think duplicate dedection doesn’t go across DBs.
You can just try it out. And yes, duplicates are apparently not detected across databases. As replicants don’t exist across databases, there detection is a non-issue.
Correct.
I did try it out. And I did notice that the same document I bad filed by accident in to different DBs did have duplicate count of 0.
That’s why I started this topic (to make sure I didn’t get anything wrong).
