Could someone explain the technical difference(s) between “Replicate To” and “Duplicate To”?
Help says:
Duplicate To > …: Duplicates the selected group to the group you select from the submenu.
Replicate To > …: Replicates the selected group to the group you select from the submenu.
This isn’t much help as In common English these words are often interchangeable:
du·pli·cate: To make an exact copy of.
rep·li·cate: To duplicate, copy, reproduce, or repeat.
Any ideas?
