In my workflow for reviewing and annotating PDF documents, I regularly switch between the Annotation pane and the list of Annotations in the ‘Inspectors’.
I find it annoying that every time I switch back to the other pane, it resets to the beginning of the annotation file or the annotations list, rather than retaining the position where I was previously.
Could you consider adding a setting to retain the current position in each pane when switching between them?
Thank you for the suggested workaround. However it does not solve my “real estate” issue (2x space occupied keeping the two windows open at the same time instead of switching)
Another option is to use the Tools > Annotation Selection tool and click an annotation on the page. It immediately jumps to it in the Document > Annotations inspector when it’s open.
This would indeed work for the document Annotations, although with an extra step, as I usually keep the Annotations toolbar in ‘Text Selection’ mode, since I am constantly selecting text to e.g. copy and paste links.
However, it does not solve the issue with the Annotations pane.
@cgrunenberg@BLUEFROG — I’m bumping this and would kindly ask you to consider my request , at least with regard to the Annotation pane.
I am reviewing PDF documents that contain numerous links to exhibits (hundreds). When I open an exhibit from the main document by clicking on a link (either with a single click, or using Cmd-click to open it in a new tab) and then return to the main document, the Annotation pane has reset to the top. This means I have to scroll back to the bottom, or press Cmd-↓ (if I am annotating at the end of the file) - every time.
Is this behaviour intentional? Is there a specific reason for resetting the pane’s position rather than retaining it?
So far it is as the internal reading position (there’s only one) is currently reserved for windows and not used by inspectors. A future release might revise this.
