Hi,
the new „go to group“ function is really great for navigating but I also would like to be able to reveal the folder in the sidepane. Is this already possible or planned ?
regards
Andreas
Hi,
regards
Andreas
Could you explain what you’re doing or show a screen shot? When navigate in Go to Group… it expands its parent groups to show me the group in the sidebar.
I just use “go to group” and choose one group.
The group is being activated and the files are displayed in the main window but the left sidebar always remains collapsed.
It doesn’t matter if I use shortcuts, keyboard or mouse for navigation and selecting.
As you asked I’m assuming the behavior usually should be different. So I restarted the program and now it’s working fine.
I also started another thread with an issue of renaming within the folder pane. Even this is working now.
I’ll try to reproduce how I got into this buggy mode.
Thank you
Please choose Help > Report Bug while pressing the Alt modifier key and send the result to cgrunenberg - at - devon-technologies.com - maybe there are useful hints in the logs. Thanks!
The Problem occurs together with this …
