Hi All
I’ve a problem in which DevonThink 3.8.6 will always save scanned documents in a lower resolution than I would like. It has done this for a long time actually and has led to me scanning in using another program and putting the scans from that in via the Inbox. Anyway I would like to sort out this issue with DevonThink so that I can use its scanning capability.
When I scan in I set the resolution in the pane on the right of the Image Capture scanning window. Then the scan goes to Imports, and in Imports it looks absolutely fine. However then I “Save” it to the Inbox and now the resolution is much lower and usually too low for me.
How can I get it to “Save” to the Inbox without losing all that resolution?
Thank you.
Patrick
