bolto
January 12, 2017, 1:39pm
#1
Trying to configure scanner to scan to DevonThink but DevonThink doesn’t show up in the list of available applications.
Here’s what i’ve got: http://d.pr/i/m57F
Please note ScanSnap software was updated yesterday.
Running macOS 10.12.2 (16C67)
Thanks
Did you already install the ScanSnap support via DEVONthink Pro Office > Install Add-Ons? Which version of DEVONthink do you use?
Unless they’ve changed the software, you should be able to add an application to this.
I have a Fujitsu iX500 and using it daily scanning documents right in to DTPO.
Symbol all the way to the right is DevonThink and then I am asked in to what group I want the document saved in.
bolto
January 12, 2017, 5:47pm
#5
Thanks for your reply. Everything is ok now.
I realized DevonThink wouldn’t get displayed automatically. I therefore added it manually to the menu of available applications in ScanSnap.
