There is a ‘Script’ field in the Info Inspector
I cannot find an explanation for this in the documentation
What is this for? Should it contain the full path to a Script file to be run when the document is viewed? Something else?
How about when the same field is populated for a Group rather than for a document?
I think it is the Attached script referred to at page 107 of the pdf user guide:
Displays the name of an AppleScript script attached to the object. This is a script that is triggered when you select the item in the database. Click the down arrow and choose: Select to choose a triggered script to attach, or Remove to remove the script from the item. See also p. 179ff.
Stephen
Got it - thank you - “Triggered Scripts” is the term to search for in the documentation
