Does anyone has a script in order to create todos in Ical directly from DevonThink? I am not practical with scripts.
Thanks in advance
Thanks in advance
Hello,
I use the following script:
tell application "iCal"
activate
set newtodo to (make new todo at end of todos of calendar "myCalendar")
tell newtodo
set priority to high priority
set summary to "myText"
Best regards,
Christophe
Thanks. It works fine!
Hi,
Thank you for the script.
This opens iCal for me but doesnât create anything. I tried when some text was selected in a new rtf in DTP and when there was nothing selected.
advice?
Any help will be appreciated.
Hi,
I didnât post my entire script because thereâs too much customization in it.
But you need to fill your variables first. Something like:
display dialog "New task : " default answer ""
set myText to the text returned of the result
activate
set newtodo to (make new todo at end of todos of calendar "My Calendar")
tell newtodo
set summary to myText
Replace âMy Calendarâ by your own calendar name.
Christophe
Works.
thank you
