Does anyone have a script for automatically setting the first line of a Note as the Name of the Note?
I appreciate that one can select the first line and then Set Title As from the contextual menu, but that’s less efficient (to me) than something I can bind to a keystroke.
Before DTP2, in List View, Icon View, and Column View, one used to be able to have a new Note open up immediately for text entry (in the other views, selection of the Name of the Note was the default). On Save, the first line of such a Note would then automatically become the Name of the Note. This functionality has now been lost and I’m looking for some reasonable replacement.
Thanks for the suggestion, but the functionality I miss is not having to do a thing to name the Note, except Save it.
Next best would be a keystroke that named the completed Note with its first line, simply from within the open Note and without any mousing around; it’s having to select text that has the highest nuisance value.
Hi Jim,
Using on RTf mostly.
It is working now, after restarting DTPO.
However, it will only work on a single file. Not when I select multiple RTFs.
The script I used before worked on multiple files. Lost that one.
