Script newbee needs help
Hi!
I’ve some wired (for me :wink: ) scripting problems.
In an smart group folder I collect entries of some groups and put them to a new one.
the wired thing is: on creation of the smart group the collection succeeds,
but on an update it fails. any idea why?
-- Smart Group for open Jobs
on run
		set scriptPath to POSIX path of (path to me)
		if scriptPath ends with "/" then set scriptPath to ""
			my triggered(create record with {name:"@ ToDo", type:group, attached script:scriptPath})
				display alert "DEVONthink Pro" message error_message as warning
			on error number error_number
				if error_number is -1708 then display dialog error_message buttons {"OK"} default button 1
end run
on triggered(theRecord)
			if type of theRecord is group then
				tell the root of the current database
					get every child where the name starts with ¬
						"@" and the type is group ¬
						and the name does not start with "@ "
				set theTodoGroups to the result
				repeat with theGroup in theTodoGroups
					repeat with theItem in every child of theGroup
						replicate record theItem to theRecord
end triggered
The script doesn’t remove replicants if necessary and doesn’t check if the smart group contains already replicants.
