For an example, I usually scan my bills into DT with my Fujitsu ScanSnap, one after the other and wind up with a folder full files entitled ScanSnap-001.pdf, ScanSnap-002.pdf, etc…Many of these bills are reoccurring monthly bills, and many of them have big, bold OCR-friendly headings that are always recognized accurately at the top of the bill…
Is it possible manually select a batch of files in DT, and then have a script search for a predefined list of OCR words/phrases to act as triggers, which if matched correctly, would automatically rename the file to a predetermined file name and then perhaps append a sequence number?
SO that If I had just scanned all of my monthly bills and there is one from “Time-Warner Cable Company” with that exact text appearing at the top of the document, then the when I run the script on this document, it could automatically be renamed from SnapScan-001.pdf to “Time-Warner Cable Company Bill_029”
This is of course possible. Basically such a script would look like this:
set theText to plain text of theRecord
-- Add code to look for & extract titles and to update theName here
set name of theRecord to theName
Seeing as how my applescripting ability is entirely non-existent, do you think you could help me figure out how to fill in the code for the section you referenced as:
I would be sincerely grateful if you could help me out with this, as it would save me hours and hours if I could get such a functionality added to DT…
Thanks, and I look forward to hearing back from you!
property pTitles : {"Time Warner", "Devon Technologies"}
set theNum to 1
repeat with pTitle in pTitles
if theText contains pTitle then
set theName to pTitle & "-" & (theNum as string)
set theNum to theNum + 1
exit repeat
You have to add your desired strings to the array pTitles.
So I can’t get this code to work. Any advice? I’m not a programmer and don’t know what or how to really use the script. I am hoping to rename files based on their group and creation date so if I drop a document into a group I want it to automatically rename itself to that group with the date appended.
Example: I’ve got a costco receipt I’ve scanned in and OCR’d via a Fujitsu Scansnap. I want that file to automatically get filed into the correct folder and renamed as I choose. I know apps like Hazel and a Better Rename can handle this, but a super powerful program like DevonThink cannot? or Do I have to script it or something? Any help greatly appreciated.
