I was told that when I do a preliminary search for example:
“feel” (depression and blog) I will obtain URLs, and can then use the URLs as search sets to drill down further to what I am looking for.
I am referred to the tutorials but I am not sure what I am doing.
I don’t think I understand the use of the search sets and then using my results properly.
I am confused with the understanding of search sets…for instance I have created a search for (depression and anxiety) and (blog)
Under plugins I have blogs and usenet ticked off
Under sites I have added sites that frequently give me such results.
I was told that I could run a search within these specific websites to drill down further, is that true?
Yes. I assume that you have created a new search set in Tools > Edit Search Sets. In that same mode, you can choose to drill down, perhaps 2 levels deep.
As Christian noted, in the Edit Search Sets mode you can enable an Action that will automatically send the search results to DEVONthink. The DEVONthink applications enable management, organization and analysis of collections of documents.
