I’m trying to create a plugin for DEVONagent that will allow it to search DEVONthink Pro Office using its web server functionality.
So far, although my DTPO search for “philosophy” turns up a large number of links (many of them plain text files), DEVONagent only sees the entries which are web pages and have an originating URL. That is, I get 47 hits in DTPO, but only 4 hits in DEVONagent. Also, double-clicking on the hits that DA does see causes it to visit the original URL, not the copy in DTPO.
Here is my plugin:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Name</key>
<string>DEVONthink Pro Office</string>
<key>Info</key>
<string>DEVONthink Pro Office Plugin 1.0 ©2007 John Wiegley</string>
<key>Description</key>
<string>Searches your DEVONthink Pro Office.</string>
<key>Version</key>
<string>1.0</string>
<key>Identifier</key>
<string>com.johnwiegley.dtpo.plugin</string>
<key>EngineUrl</key>
<string>http://localhost:8080/search?q=_agentQuery_&w=4&o=0&c=0&start=_agentOffset_&num=_agentNumber_</string>
<key>EncodingUrl</key>
<string>UTF-8</string>
<key>Start</key>
<integer>0</integer>
<key>OffsetPerPage</key>
<integer>100</integer>
<key>ResultsPerPage</key>
<key>LinksStart</key>
<string><ol start=</string>
<key>LinksEnd</key>
<string></ol></string>
<key>Keyword</key>
<string>dtp</string>
</dict>
</plist>
Note that I’m guessing this has to do with the way that DTPO’s server outputs the href links:
<a href="rands.philosophy.txt?id=584021&action=view" set="yes">rands.<span class="markup">philosophy</span>.txt</a>
Since it’s a server-relative URL without an HTML extension, perhaps DA is ignoring it. But since it is browsable, shouldn’t there be a way to get DA to show it as a hit?
Getting this to work would be a great way to add my DEVONthink database to my typical “Fast Scan” search set, letting me search against whatever I have archived there, since I tend not to use the DEVONagent archive much.
Thank you,
John
