Searching through pdf
Hi,
I have a database with a lot of pdf documents and I will like to search through
pdf. Is that possible in DevonThink ?
Thanks
AS
Yes. The exception would be image-only PDFs (which contain no text) or encrypted PDFs documents.
Yup. I figured out what error I was making.
Since I have you attention, is it possible to annotate/make notes
right on the pdf in DTpro ?
Not yet. But this might be possible in V2.0.
AS:
In the interim, you can make brief notes in the Comment field of the Info panel that’s associated with a PDF (or any other document in your database).
Notes in the Comment field are searchable.
