Hi, all of a sudden, the ‘Send by email’ function does not work anymore. When I use the contextual menu or the button in the toolbar, Devon switches to Apple Mail, but it won’t create a new message nor does it attach the selected document(s).
Other strange thing is that for some specific downloaded pdf-files, these file had be to saved to some folder (using Export > Files and folders) and then attach it in a Mail-message using the Attachments-button in Mail; I could not get it dragged and dropped directly from DTPO to a new mail message.
However, for other pdf’s that were created using the scanner (ScanSnap), the drag n drop did function as expected.
The Send by email function used to work perfectly, don’t know what might have changed this.
After this I checked for updates, DevonThinkPro now has version 2.11.3. Issue persists.
Working on a MacPro 2013 running Mojave 10.14.3
Apple Mail Version 12.2 (3445.102.3)
Have restarted the Mac, restarted DTPO, restarted Apple Mail. No difference.
Any idea what the issue can be?
Thnx,
Henk-Jan
