Is it possible to modify this line of AppleScript to refer to a smart group instead of a group?
set theGroupUUID to
thank you
set theGroupUUID to
thank you
UUID is UUID, just set it.
However as you didn’t wrote what the script does it’s not possible to tell whether replacing a group with a Smart Group will work at all.
Thank you @pete31 for your reply ! It’s your excellent goto group script that I use all the time !
I tried simply inserting the UUID of the recently added smartgroup instead of a group, but it does not work.
As a substitute, I am using the keyboard maestro action below, but it is certainly not as good as your script. It is slower and opens a new window every time I run it.
I want to take the opportunity to apologize for irritating you a while back. I sincerely did not understand what you were asking for. The end result was that I appeared unappreciative of your tireless help and I totally understand how insulting that can be. When I look at the number of scripts that I use and that you wrote, I realize how big an impact you have had on my daily DevonThink workflow.
set theGroupUUID to "AB61FF8F-EBD8-474F-B22E-A863D01183E2" -- insert group UUID here
set theGroup to (get record with uuid theGroupUUID)
if exists (viewer window 1) then
set root of viewer window 1 to theGroup
else
open window for record theGroup
activate
return
Why don’t you just add the group to your Favorites for quick access?
yes, it’s a workaround. thank you
there does not seem to be a way to add a smart group to favorites, neither in the context menu, nor in the main menu. I managed once in the main menu to data → add to → favorites but it did not appear in the favorites list
Global smart groups can’t be added to the Favorites. Local smart groups can.
OK thanks
You’re welcome
Using small groups answers my initial question because @pete31 's “go to ”AppleScript works with local smart groups
