When I select text in a web archive and choose the script “Set Title As” (called “Set Title As___Ctrl-Alt-T.scpt” in my menu) from the Scripts>Rename menu, it works as expected.
If, however, I choose to use the keyboard shortcut of control-option-t, the text in the web archive is deleted. I think this has been true for several beta versions.
That’s true. Scripts > Rename lists three scripts, each with a keyboard shortcut, to rename a document using selected text. I didn’t examine the scripts, but I tried all three to rename a WebArchive document. The first and third scripts worked correctly using their keyboard shortcuts.
The second of the three scripts shows a keyboard shortcut, Control-Option-T.
If I select text in a WebArchive document and click on the script in the Scrips menu, that script works correctly.
But if I use the keyboard shortcut, Control-Option-T, the document is renamed BUT the selected text is deleted.
So – there appears to be something weird about the keyboard shortcut, not the script itself.
After some poking around and following links, I realized I’d used the Keyboard Shortcuts preferences pane to assign Cmd-Ctrl-Alt-T to Tables… . I swapped those around and everything seems to be working now.
