I’m scanning a number of old hand-written letters with ScanSnap into DTPO. The documents are fragile, usually both sides, and I’m using a ScanSnap carrier sheet. The handwriting in most documents is very close to the edge, in pencil, on non-standard size papers (writing materials were scarce for this situation).
When ScanSnap makes the PDF it is cropping off portions of the document, cutting off the handwriting. I’ve set the “Carrier Sheet Settings” to “Carrier Sheet Size”, which eliminates the cropping but makes for large pages on which the text gets lost. Workable, but not the best solution. Auto sizing doesn’t work - that’s when the cropping occurs.
I realize this is not directly a DTPO question, but wonder if anyone has solved a similar problem of overly-cropped documents using ScanSnap?
