With all databases closed, or one or more databases open, I am seeing a solid gray dot on the far right side of Sidebar > Globals > Inbox entry. What is that indicating?
It’s identical to the gray dot that displays in the same location as the synchronization required dot in Sidebar > Open Databases > databasename.
Synchronizing Globals > Inbox cleared the dot indicator. I did not understand that it may also require synchronization. I was only synchronizing Open Databases. Thank you for clarifying.
