I am certainly being very dense, but can’t find it
Double clicking on a smart rule or CTRL-click then selecting edit will open a smart rule.
I have looked through all the menus and used CheatSheet. No direct keyboard shortcut comes up. You may be able to set one using KM or something equivalent.
Yep, thanks - I’ve been right-clicking the rule, and getting lazy Will try and set up something via KM.
Seems like KM can’t do it, and it would either take some shell script to double-click at the cursor location, or UI Applescripting by clicking the menu then a menu item (in the contextual menu). So, super hard and not worth it.
Unless someone has some smarter than mine ideas…
One can always count on @BLUEFROG to have smarter than mine ideas
thanks!
Done & happy, tx!
