Hi all,
First off, downloaded the third beta of DevonThink Pro and loving it. Great look, a lot of improvements, and will only get easier to recommend it for others to use.
There is one regression that I wanted to point out though:
Some notes/docs that I write include a mix of “regular” and “fixed width” fonts, and earlier I had a keyboard shortcut that would trigger the Mono font style for a selected piece of text.
I can still see this style if I go through Format->Style->Styles…, but somehow it isn’t part of the menu, so it can’t be triggered via a keyboard shortcut, which means there’s no quick-n-easy way to change the font for a selected piece of text anymore.
Am I missing something obvious here? Is there a workaround for this?
Cheers,
Agam
