Hi all.
Is there a way to build an expression to create a Smart Group that find pdfs that have not yet been converted to searchable? Can’t figure it out…
tks,
André
Either in the smart group editor or in the Advanced button of the full search window set these criteria:
All of the following are true:
Kind is PDF/PS
Word Count is 0
If this was done in the full Search window, click on the “+” button to the right of the query field, then name and save the new smart group.
Image-only PDFs will be listed, and these are candidates for OCR.
Works!
Tks a lot!
Or just use the template Smart Groups > PDFs (not searchable).
Criss, that smart group makes it too easy.
Sometimes we can make a teachable moment, demonstrating both how a smart group is defined and how easy it is to create a new one.
