Smart Group Parameter+ for "Flagged"?
I’m editing a Smart Group to search for flagged files. I can search “item:flagged”, but I wanted to put make it one of Smart Group’s several parameters. Can’t seem to find it.
– Gerry
It is Marked related to it being listed in the Data > Mark menu.
Tip: If you already know the search prefix, enable Advanced search. This shows an interface similar to what you see in the Smart Group/Rule editor. But it live-updates to reflect what you enter in the search bar. The reverse is also true: the search bar live-updates to reflect changes you make in the GUI. This is a very nice way to learn experientially.
When in doubt, you can always look in the manual under Appendix > Search prefixes
Got it, thanks. Just didn’t realized that “flagged” is identified as “marked” in the selection menu of smart rules.
From the Help menu…
Ah, yes. There are always breadcrumbs on the way to the gingerbread house. I undoubtedly saw this but did not interpret it correctly.
I assume, despite pawing through all the docu and help menus I’ll remain stupid in many things DEVONThink.
Thanks again!
– Gerry
You’re welcome.
