I have imported (via indexing) a ton of files into DT3.
Now, most of them reside in one rather big group with sub-groups, and I want to sort them into various groups on the first level of the database.
I thought I could just create a smart group which shows only those files contained in the one big “Files” group. However, I ran into the following problems:
A smart group can have many conditions, but a very powerful one is missing: “does not contain” !
I want to a condition to check the location of a file (i.e. the group name), but it is not listed in the available items.
In list view, DT3 can display the group path (breadcrumb) of a file, but this location item can’t be chosen in smart group conditions.
To complete the confusion: both the group path of the file and its geographical location (of a photo, for example) are BOTH named “Ort” in the German version… ugh!
So… can I please get “does not contain” and the breadcrumb/location of a file as a choice in smart groups?
Reiterating:
When I create a smart group, there is the option for example:
“Name” CONTAINS “something”
This works for comment, title, topic, basically anything that is not only numbers and yes/no.
What we are asking for is the feature
“Name” DOES NOT CONTAIN “something” as smart folder criterium.
Suggestion:
Assign tags to any groups to be excluded/included with a tag name that is the same as the group name ( with database properties “Excluded Groups from Tagging” turned on), you can also add a prefix or change the tag color to differentiate those tags from the normal tags. In your smart rule/group, add additional criteria of “Tag is”/“Tag is not" to the tag name of groups to be included/excluded.
With this method, you can (1) search in multiple sub-groups in one smart rule/group, or (2) search in a larger parent group but able to exclude any sub-groups that are not wanted.
