Smart rule for renaming downloads?
This script works well for renaming web archives to the title of the web page.
    			set this_count to count of this_selection
    			if this_count > 0 then
    				show progress indicator "Renaming" steps this_count
    				repeat with this_item in this_selection
    					set this_type to the type of this_item
    					set this_source to missing value
    					step progress indicator (name of this_item) as string
    					if this_type is equal to html or this_type is equal to webarchive then
    						set this_source to source of this_item
    					else if this_type is equal to bookmark then
    						set this_URL to the URL of this_item
    						if this_URL is not "" then set this_source to download markup from this_URL
    					if this_source is not missing value then
    						set this_title to get title of this_source
    						if this_title is not missing value and this_title is not "" then set the name of this_item to this_title
    				hide progress indicator
However, I want to adapt it as a smart rule for use when a web page lands in the Downloads folder. Any thoughts on how?
I too, have similar question.
would like to have IMG(pictures) renamed after it is synced(imported) to DevonThink3 from DTTG on the title. Renamed it to the current date.
Wonder how can I do this with the current Smart Rules.
There’s no AppleScript needed for this. Here’s a simple example.
Notes:
  1. Sortable Date is the Current Date > YYYY-MM-DD option in the Placeholders.
  2. You should be specific in the group you target.
  3. If you target a group with subgroups, the subgroups will also be processed. this may or may not be desirable.
Thanks Jim :wink:
