Hi,
I searched the forum, but I didn’t find a hint, why only of my two rules works as it should. The PNG-files gets deleted, the html-file stays in the inbox.
Any ideas?
Regards
Andreas
Hi,
Any ideas?
Regards
Andreas
You could try to
Move to trash
from your smart rule.Those are my settings, and they work just fine with a smart rule that OCRs PDFs using “OCR apply” after importing from a scanner.
This preference doesn’t affect smart rules. But in the second rule the OCR > Apply action is unnecessary.
Because a PDF converted from HTML does obviously contain a text layer (unless the HTML contains only image(s), I guess – though I’m not sure what the PDF created from that contains).
Why aren’t you just clipping directly to paginated PDF?
I got used to ‘SingeFile’ for clipping.
Indeed! Thanks for the tip.
And the html file gets moved to the trash - although I don’t understand, what makes the difference.
Then why aren’t you just using the HTML from SingleFile?
PDF seems more like a ‘real’ document to me - and sometimes I use the file outside of DevonThink.
