Tempted to chalk this one up to computer weather. I have a Smart Rule that “archives” files fitting a few conditions by moving them to a different database.
I wrote a script to do the moving. It works on selections (e.g., when debugging). It then failed (silently) when I attached it to the smart rule as an external script (e.g., I saved it in the Script folder’s Smart Rules subfolder and selected it in the drop-down menu, then hit “Apply rule” on the script when it showed some files fit the conditions).
In the course of debugging, I tried embedding the script—just copied and pasted the text from the external file to the embedded dialogue.
It worked.
I guess this is fine, but why? Any ideas?
Could you please post the source of the script? Thanks.
Sure thing:
repeat with eachRecord in theRecords
set archiveDatabase to get database with uuid "ADB9D9D0-0304-43F4-A187-945F15A4777C"
display dialog ("Confirm archival of \"" & name of eachRecord as string) & "\"."
set theLocation to get location of eachRecord
set sourceRecord to the parent of eachRecord
set parentRecord to the first item of parent of eachRecord
create location theLocation in archiveDatabase
set destinationRecord to get record at theLocation in archiveDatabase
-- create a link to the archive group, for convenience
set destinationLink to reference URL of destinationRecord
set destinationLinkRecordName to "Archive - " & name of parentRecord
set searchRecords to (lookup records with path (path of parentRecord) & "/" & destinationLinkRecordName & ".inetloc") in sourceRecord
log searchRecords
if searchRecords is not {} then
set archiveRecord to the first item in searchRecords
else
set archiveRecord to create record with {name:destinationLinkRecordName, type:bookmark, URL:destinationLink} in parentRecord
if eachRecord is indexed then
consolidate record eachRecord
--move the record to the archive database
move record eachRecord to destinationRecord from sourceRecord
end performSmartRule
Open to feedback, too! I’m sure it’s clunky.
I just tried this successfully using a simple smart rule that is performed on demand. Which macOS version do you use? By the way, user interaction in smart rule scripts is usually not recommended as smart rules should ideally work facelessly.
Hm. Computer weather it is, maybe… Using Catalina these days.
Good point re: the confirmation prompt. I wanted to make sure it worked as expected but I’ll disable it now.
Just a minor modification, but it’s working as an embedded script here…
set parentRecord to parent 1 of eachRecord
set searchRecords to (lookup records with path (path of parentRecord) & "/" & destinationLinkRecordName & ".inetloc") in parentRecord
log searchRecords
else
Thanks! My original plan, though, was to get it working as an external script.
But this works! I am content.
Haha! I just noticed that.
PS: I just set up my code as an external script and it worked as expected.
