Success! It’s working beautifully now!
Pete, this has been really helpful. Thanks again, also for pushing me a bit to find the solution on my own - that’s how one learns, right?
Here are the scripts, in case someone wants to use them.
Working smart rule script:
set theText to plain text of theRecord as string
if theText ≠ "" then
set newText to script "ScriptLibraryReplacekeyword"'s replacekeyword(theText, "DT_Inbox")
if newText ≠ theText and newText ≠ "" and newText ≠ "missing value" then set plain text of theRecord to newText
end performSmartRule
And this is the Script Library:
-- Script Library - replacekeyword
use AppleScript version "2.7"
use framework "Foundation"
use scripting additions
on replacekeyword(theText)
set ca to a reference to current application
set theString to ca's NSString's stringWithString:theText
set newString to theString's stringByReplacingOccurrencesOfString:("DT_Inbox") withString:("") options:(ca's NSRegularExpressionSearch) range:{location:0, |length|:length of theText}
set newText to newString as string
error number -128
end replacekeyword
