Smart Rules - Extras skipped on installation
I can install Scripts and Templates from the smart rules dialog (scripts>more scripts), but when I try to install the smart rule to ocr screenshots, it greys out the button to say its installed, but the log says skipped, and it clearly isn’t there. Any suggestions?
Sure… I suggest you include screen captures of what you’re trying to install as well as your installed smart rules. :smiley:
