I just upgraded to Ventura… when using DT, I now have a problem that after searching, and clicking on the search result in the list, the doc tries to loads, then the search result for that file just vanishes.
When I search again using the same keyword, the doc doesn’t appear in the search results.
Anyone else had this issue? - Feeling nervous about where the docs are going as well.
Argh - I’ve just worked it out… Mac OS has changed the name of a folder that the files are referenced from so DT has lost all its links. [For a good reason] I’ve indexed a sub-folder of Mail in DT to capture all the PDFs that come into a mail folder - they then get indexed automatically.
Mail has now moved its mail folder from ~/Library/Mail/V9 to V10… so all the indexed files have lost their reference.
Is there any way to update all links with this change in the database? or do I have to re-index the whole folder?
Indexing the Apple Mail directory in the User Library is technically possible but we don’t advocate it.
Using the Apple Mail plugin to import emails or archive mailboxes is the suggested method.
