Some tags will not show when using "Reveal tag"
As title.
It happens most when the tag is in hierarchy.
As in this GIF.
Version 4 beta 3.
What kind of tag (ordinary or group tag)? And are unified tags en- or disabled, see Settings > General > Interface > Sidebar?
Group tag. The one at the bottom.
“Unified tags” is enabled.
A screenshot of Settings > General > Interface would be useful, thank you.
Here it is.
So far we couldn’t reproduce this using the same settings. Are you able to reproduce this using a new, simple database that you could share?
Yes, it’s easy to reproduce.
I set a new database up, and arranged a tag group like this:
( I made tag “a4” an aliases named “b1”)
And I created a new Markdown file name “test”, then tag it with “b1”.
I used the tag “a4” to reveal tag, and the problem happened again.
Please export this database via File > Export > Database Archive… and send it to cgrunenberg - at - devon-technologies.com. Thanks!
Done.
But I’m not sure if I sent the file correctly.
