Hello group,
my documents are structured inside the database in different “folders”. I can see the place (= folder-path inside the DB) in detail-view, when activating the “Place” column.
(Don’t now the english name, but its the one after URL and Path.)
It is not possible to activate this column in SearchResult-view. But I would need it to sort results by place.
In normal folder-view one can activate this column - but it only makes some sense for replicates. All other files just show the place you went to.
Is there a way to sort SearchResults by the place I filed the document?
Vinz
