Hi,
e.g. creating a new markdown/plain text item via sorter, in the Body, the character code for :
APOSTROPHE
Unicode: U+0027, UTF-8: 27
is converted in :
LEFT SINGLE QUOTATION MARK
Unicode: U+2018, UTF-8: E2 80 98
in the database the item name (automatic) remain LEFT SINGLE QUOTATION MARK
this does not happens directly filling sorter Name field
Are smart quotes enabled in the Sorter?
yes…never used, sorry.
Thanks
Hi,
a little problem again with quotes in sorter with automatic name:
Body |
Names |
Correct |
'abc |
abc |
yes |
!abc |
'!abc |
yes |
'abc def |
'abc def |
yes |
'!abc def |
def |
no |
It’s intentional that automatic naming skips certain things. How does a real world example look like in the last case?
I use quote and exlamation point as shortcut, they are parsed by smart rules and set correspondant metadata.
Anyway was just a little note about changement in behaviour from previous version.
